base64Encode
Converts a String or byte[] using Base64 encoding, using the UTF-8 character set. For example, given a schema such as:
{ "type": "record", "name": "events", "fields": [ { "name": "name", "type": "string" } ] }
and a record such as:
{ "name" : "John" }
The following record path expression would encode the String using Base64:
RecordPath |
Return value |
Sm9obg== |
