FileAuthorizer
The FileAuthorizer has been replaced with the more granular StandardManagedAuthorizer approach described above. However, it is still available for backwards compatibility reasons. The FileAuthorizer has the following properties:
Property Name Description
Authorizations File
The file where the FileAuthorizer stores policies. By default, the authorizations.xml in the conf directory is chosen.
Users File
The file where the FileAuthorizer stores users and groups. By default, the users.xml in the conf directory is chosen.
Initial Admin Identity
The identity of an initial admin user that is granted access to the UI and given the ability to create additional users, groups, and policies. This property is only used when there are no other users, groups, and policies defined.
Legacy Authorized Users File
The full path to an existing authorized-users.xml that is automatically converted to the multi-tenant authorization model. This property is only used when there are no other users, groups, and policies defined.
Node Identity
The identity of a NiFi cluster node. When clustered, a property for each node should be defined, so that every node knows about every other node. If not clustered, these properties can be ignored.
