NiFi
The following table lists the default ports used by NiFi and the corresponding property in the nifi.properties file.
Function Property Default Value
HTTPS Port
nifi.web.https.port
8443
Remote Input Socket Port*
nifi.remote.input.socket.port
10443
Cluster Node Protocol Port*
nifi.cluster.node.protocol.port
11443
Cluster Node Load Balancing Port
nifi.cluster.node.load.balance.port
6342
Web HTTP Forwarding Port
nifi.web.http.port.forwarding
none
