Apache NiFi Registry Admin GuidePDF version
How to install and start NiFi Registry
  • Linux/Unix/OS X
    • Decompress and untar into desired installation directory
    • Make any desired edits in files found under <installdir>/conf
    • From the <installdir>/bin directory, execute the following commands by typing ./nifi-registry.sh <command>:
      • start: starts NiFi Registry in the background
      • stop: stops NiFi Registry that is running in the background
      • status: provides the current status of NiFi Registry
      • run: runs NiFi Registry in the foreground and waits for a Ctrl-C to initiate shutdown of NiFi Registry
      • install: installs NiFi Registry as a service that can then be controlled via
        • service nifi-registry start
        • service nifi-registry stop
        • service nifi-registry status
When NiFi Registry first starts up, the following directories are created:
  • flow_storage
  • database
  • work
  • logs
  • run
See the System Properties section of this guide for more information about NiFi Registry configuration files.
