Encrypted File System Content Repository Properties
All of the properties defined above (see File System Content Repository Properties) still apply. Only encryption-specific properties are listed here. See Encryption Configuration for more information.
Property
Description
nifi.content.repository.encryption.key.provider.implementation
This is the fully-qualified class name of the key provider. A key provider is the datastore interface for accessing the encryption key to protect the content claims. There are currently three implementations: StaticKeyProvider which reads a key directly from nifi.properties, FileBasedKeyProvider which reads keys from an encrypted file, and KeyStoreKeyProvider which reads keys from a standard java.security.KeyStore.
nifi.content.repository.encryption.key.provider.location
The path to the key definition resource (empty for StaticKeyProvider, ./keys.nkp or similar path for FileBasedKeyProvider). For future providers like an HSM, this may be a connection string or URL.
nifi.content.repository.encryption.key.provider.password
The password used for decrypting the key definition resource, such as the keystore for KeyStoreKeyProvider.
nifi.content.repository.encryption.key.id
The active key ID to use for encryption (e.g. Key1).
The key to use for StaticKeyProvider. The key format is hex-encoded (0123456789ABCDEFFEDCBA98765432100123456789ABCDEFFEDCBA9876543210) but can also be encrypted using the ./encrypt-config.sh tool in NiFi Toolkit.
nifi.content.repository.encryption.key.id.*
Allows for additional keys to be specified for the StaticKeyProvider. For example, the line nifi.content.repository.encryption.key.id.Key2=012…​210 would provide an available key Key2.
