Using the Apache NiFi ToolkitPDF version
AWS_KMS
This protection scheme uses https://aws.amazon.com/kms/ Service for encryption and decryption. AWS KMS configuration properties can be stored in the bootstrap-aws.conf file, as referenced in the bootstrap.conf of NiFi or NiFi Registry. If the configuration properties are not specified in bootstrap-aws.conf, then the provider will attempt to use the AWS default credentials provider, which checks standard environment variables and system properties. Therefore, when using the AWS_KMS protection scheme, the nifi(.registry)?.bootstrap.protection.aws.conf property in the bootstrap.conf specified using the -b flag must be available to the Encrypt Configuration Tool and must be configured.
