Name your flow
When you add a flow to an existing deployment you must provide a flow name that is unique within that deployment.
  1. Provide a unique Flow Name.
    This name helps you distinguish between individual instances of a flow within a deployment.
  2. Optional: If you do not want the flow to start running after deployment, unselect the Automatically start flow upon successful deployment checkbox.
  3. Click Next .
