Adding a flow to an existing deployment
Follow these instructions to deploy a flow definition into an existing cluster to run an Apache NiFi flow in Cloudera Data Flow. You do this by selecting a flow definition and launching the deployment wizard, where you select an environment, provide values for required parameters, configure sizing, and KPIs.
  1. Select Catalog from the left navigation pane.
    Flow definitions available for you to deploy are displayed, one definition per row.
  2. Select a flow definition to view details and available versions.
    The Flow Definition Details view opens.
  3. Select a flow definition version then click Deploy to launch the deployment wizard.
  4. Select Add to Existing Deployment to deploy the flow on an existing NiFi cluster.
  5. In the Add Flow to Existing Deployment modal, select the deployment where you want to add the new flow and click Continue .
