Provide parameter values
Depending on the flow you deploy, you may need to specify parameter values like connection strings or credentials, and upload files like truststores or JARs.
Provide values to parameters required for your flow deployment.
You have to provide values for all parameters.
You may edit parameters individually by clicking the edit
icon next to them or you may edit entire parameter groups by selecting the
Edit Group option.
In either case, you have the option to define a custom parameter value that is specific to this deployment or, if available, select the value from a shared parameter group.
You may import a set of shared parameters from a parameter group to fill in
values and facilitate flow deployment. To do so, select the
Import Shared Parameters option.
Parameters in the shared group that match a deployment parameter are preselected, unless you have already modified that parameter in the deployment wizard. In that case that particular parameter is left unselected to protect any changes you have already made and you need to manually select that parameter.
When you finish setting configuration parameters, click Next
