Creating a draft from a flow definition in the Catalog
You can open flow definitions in the Catalog as drafts in Flow Designer. Depending on whether the flow definition has associated flow drafts or not, you may have more than one option.
You can create a new draft from an existing flow definition in the Catalog. This gives you two options:
  • You can update the existing flow definition by creating a draft and then publish your work as a new version of the source flow definition.
  • You can create a draft using the source flow definition as a template and then publishing your work as a new flow definition.
  1. Select Catalog in the left navigation pane.
  2. Select the flow that you want to open as a draft.
  3. You may have two options at this step:
    • If the flow definition has no associated drafts, or you want to create a new draft based on the flow definition, select Actions > Create New Draft.
    • If there is already an ASSOCIATED DRAFT, you can select this draft and open it for editing in the Flow Design view.
  4. Provide a Draft Name.
  5. Click Create.
    If the source flow definition contains more than one parameter context, the Map Parameter Contexts page opens. If parameter matching is not necessary, the draft opens in the Flow Designer.
  6. If the source flow definition contains more than one parameter context, the Map Parameter Contexts page opens. This is the step where you can review the suggested shared parameter groups to replace parameter contexts in your flow definitions.
  7. Click Create Flow Draft.
Proceed according to Creating a draft.
