Editing test session configuration
After suspending a test session, you can modify the configuration of the NiFi underlying cluster.
You must have the cdf-flow-admin role assigned to you to perform this task For more information, see Cloudera Data Flow user roles.
- You have a suspended test session in Flow Designer.
In Flow Designer, go to
You can update:
- NiFi runtime version
- NiFi node sizing
