Publish your flow definition to the Catalog
Now that you have tested your draft and it works fine, you can go on and publish it to the Catalog as a flow definition so that you can create a Cloudera Data Flow deployment.
  1. On the Flow Designer canvas, go to Flow Options > Publish.
  2. Fill in the fields in the Publish A New Flow modal window.
    • Provide a Flow Name for your flow definition.
      You can only provide a name when you publish your flow for the first time, it cannot be changed later.
    • Optionally, provide a Flow Description.
      You can only provide a description when you publish your flow for the first time.
    • Optionally, provide Custom Tags.
      You can filter flow definition versions by tags in the Catalog.
    • Optionally, provide Version Comments.
  3. Click the Publish button.
Your draft is published to the Catalog as a flow definition.
