Publishing a new draft
When you publish a new draft for the first time, you publish it as a new flow definition.
  • You must have the cdf-flow-admin role assigned to you to perform this task For more information, see Cloudera Data Flow user roles.
  1. In the Flow Designer canvas view, click Flow Options > Publish.
  2. Fill in the fields in the Publish A New Flow box.
    • Provide a Flow Name for your flow definition.
      You can only provide a name when you publish your flow for the first time.
    • Optionally provide a Flow Description.
      You can only provide a description when you publish your flow for the first time.
    • Optionally specify one or more Custom Tag.
      Custom tags help you visually distinguish and filter for flow definitions in the Catalog.
    • Optionally provide Version Comments.
  3. Click Publish.
Your draft is published to the Catalog as a new flow definition.
