Publishing a draft as a new flow definition
When you publish a new draft for the first time, you publish it as a new flow definition. When you have publish a draft created from an existing flow definition, you can publish it as a new flow definition or a new version of the osource flow definition.
  • You must have the cdf-flow-admin role assigned to you to perform this task For more information, see Cloudera Data Flow user roles.
