Suspending a test session
When you suspend a test session your draft stops processing data and the underlying cloud resources are torn down, while maintaining flow persistence. A test session is not billable while it is suspended.
You must have the cdf-flow-admin role assigned to you to perform this task For more information, see Cloudera Data Flow user roles.
- You have a running test session in Flow Designer.
Suspend a test session by clicking the
Active Test
Session status marker, then click
Suspend
Test session status changes to
Suspending Test Session...
