Prerequisites
Learn how to collect the information you need to deploy the Box to S3 ReadyFlow, and meet other prerequisites.
For your data ingest source
A pre-configured Box App under the Box Account owning the resources being accessed (https://app.box.com/developers/console), with the following configuration:
  • If you create a new App, select Server Authentication (with JWT) authentication method. If you want to use an existing App, choose one with OAuth 2.0 with JSON Web Tokens (Server Authentication) as the Authentication method.
  • Make sure the App has a Client ID and a Client Secret.
  • Set App Access Level to App + Enterprise Access.
  • Enable Write all files and folders in Box for Application Scopes.
  • Enable the Advanced Features: Generate user access tokens and Make API calls using the as-user header.
  • Generate a Public/Private Keypair under Add and Manage Public Keys and download the configuration JSON file (under App Settings). Upload this file using the Box App Config File parameter.
  • After you have made all the above settings, you need to reauthorize the App on the admin page (Reauthorize App at https://app.box.com/master/custom-apps). If the app is configured for the first time, you need to add it (Add App) before it can be authorized.
  • You have your Box Account ID and Box Folder ID.
For Cloudera Data Flow
  • You have a Cloudera Data Flow service deployed on Cloudera Anywhere Cloud.
For your data ingest target
  • You have the destination S3 region, bucket, path, access key ID, and secret access key.
  • You have access to the destination S3 bucket.
