Box to S3 required parameters
When deploying the Box to S3 ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
Table 1. Box to S3 ReadyFlow configuration parameters
Parameter Name Description
AWS Access Key ID Specify the AWS access key ID.
AWS Secret Access Key Specify the AWS secret access key.
Box Account ID Specify your Box Account ID.
Box App Config File Upload the Box App config file in JSON format.
Box Folder ID Specify the ID of the Box folder you want to read from.
Destination S3 Bucket Specify the name of the destination S3 bucket you want to write to.
Destination S3 Path Specify the path within the destination bucket where you want to write to.
Destination S3 Region Specify the AWS region in which your destination bucket was created.
Include Subfolder Files Specify whether to include list of files from subfolders. Set to "true" to include files from subfolders. Set to "false" to only list files from the specified Box folder.
