Prerequisites
Learn how to collect the information you need to deploy the Azure Event Hub to ADLS ReadyFlow, and meet other prerequisites.
For your data ingest source
  • You have obtained the Event Hub Namespace and Instance name
    • Navigate to Event Hubs and select your Event Hub instance (msignite, in this example):
    • Copy the namespace and the Event Hub Instance name (msignite/msignite in this example).
  • You have created an Event Hub Shared Access Policy and obtained its name and Primary Access Key
    • Click Shared access policies.
    • Set up a shared access policy that allows “Listen”. Copy the Policy name.
      • Select the policy and copy the primary key.
  • You have created a consumer group.
    • Click Consumer groups.
    • Use the $Default consumer group or create your own group for the ReadyFlow:
For Cloudera Data Flow
  • You have a Cloudera Data Flow service deployed on Cloudera Anywhere Cloud.
For your data ingest target
  • You have the destination ADLS file system/container name, path, and storage account name and key.
  • You have access to the destination ADLS directory.
