Azure Event Hub to ADLS required parameters
When deploying the Azure Event Hub to ADLS ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
Table 1. Azure Event Hub to ADLS ReadyFlow configuration parameters
Parameter Name Description
ADLS File System Specify the name of the destination ADLS file system also known as container.
ADLS Path Specify the path within the destination container where you want to write to.
ADLS Storage Account Key Specify the destination ADLS storage account key.
ADLS Storage Account Name Specify the destination ADLS storage account name.
CSV Delimiter If your source data is CSV, specify the delimiter here. The default value is ,.
Data Input Format Specify the format of your input data. You can use "CSV", "JSON" or "AVRO" with this ReadyFlow.
Data Output Format Specify the desired format for your output data. You can use "CSV", "JSON" or "AVRO" with this ReadyFlow.
Event Hub Access Policy Name Specify the Access Policy Name that this flow should use.
The full path for the event hub endpoint will be constructed from:
sb://#{Event Hub Namespace}.#{Event Hub Service Bus Endpoint}/;SharedAccessKeyName=#{Event Hub Access Policy Name};SharedAccessKey=#{Event Hub Access Primary Key}
Event Hub Access Primary Key Specify the Primary Key that allows clients to use the Access Policy that you provided earlier.
Event Hub Consumer Group Specify the Event Hub Consumer Group you want to use with this flow. Any consumer group other than $Default needs to be created in Event Hub first.
Event Hub Instance Name Specify the Event Hub Instance Name inside the Event Hub Namespace you want to use.
Event Hub Namespace Specify the Event Hub Namespace which contains the Event Hub instance you want to use.
Event Hub Service Bus Endpoint Specify the Event Hub Service Bus Endpoint.
The default value is .servicebus.windows.net.
Filter Rule Specify the filter rule expressed in SQL to filter streaming events for the destination object store. Records matching the filter will be written to the destination object store. The default value forwards all records.
Schema Text Specify the Avro-formatted schema to be used for the source event hub data.
