Prerequisites
Learn how to collect the information you need to deploy the MQTT filter to Kafka ReadyFlow, and meet other prerequisites.
For your data ingest source
  • You have the MQTT broker URI.
  • You have the MQTT broker username and password.
  • You have the MQTT topic filter to designate which source topics to subscribe to.
  • You have created a schema for your data and registered it in AWS Glue Schema Registry.
  • You have the schema name and Schema Registry name.
  • You have the AWS region, access key ID, and secret access key for your AWS resources.
For Cloudera Data Flow
  • You have a Cloudera Data Flow service deployed on Cloudera Anywhere Cloud.
For your data ingest target
  • You have a Kafka cluster with a destination topic configured for your ingest flow.
  • You have the Kafka broker endpoint.
  • You have the Kafka destination topic name.
  • You have the SASL username and password to access your Kafka cluster via SASL/SCRAM authentication.
  • You have access to write to the destination Kafka topic.
