MQTT filter to Kafka required parameters
When deploying the MQTT filter to Kafka ReadyFlow, you have to provide the following parameters. Use the information you collected in Prerequisites.
Table 1. MQTT filter to Kafka ReadyFlow configuration parameters
Parameter Name Description
MQTT Broker URI Specify the URI to use to connect to the MQTT broker.
MQTT Broker Username Specify the username to use when connecting to the MQTT broker.
MQTT Broker Password Specify the password to use when connecting to the MQTT broker.
MQTT Topic Filter Specify the MQTT topic filter to designate the topics to subscribe to.
Data Input Format Specify the format of your input data. You can use "CSV", "JSON" or "AVRO" with this ReadyFlow.
CSV Delimiter If your source data is CSV, specify the delimiter here. The default value is ,.
Filter Rule Specify the filter rule expressed in SQL to filter streaming events for the destination topic. Records matching the filter are written to the destination topic. The default value forwards all records.
Schema Name Specify the schema name to be looked up in the Schema Registry.
Schema Registry Name Specify the name of the Schema Registry you want to connect to.
AWS Region Specify the AWS region in which your source, destination and schema was created.
AWS Access Key ID Specify the AWS access key ID.
AWS Secret Access Key Specify the AWS secret access key.
Data Output Format Specify the desired format for your output data. You can use "CSV", "JSON" or "AVRO" with this ReadyFlow.
Kafka Broker Endpoint Specify the Kafka bootstrap servers string as a comma separated list.
Kafka Destination Topic Specify the destination topic name.
SASL Username Specify the username to access your Kafka cluster via SASL/SCRAM authentication.
SASL Password Specify the password to access your Kafka cluster via SASL/SCRAM authentication.
