Modify a federation connector
Learn how you can modify the configuration details of an existing connector.
  1. Log in to the Cloudera Lakehouse Engine instance.
  2. On the instance page, click the Connectors tab.
    The connector list is displayed.
  3. In the Connector Name column, click the connector that you want to modify.
  4. In the connector page, click the General details tab to edit the connector name and description.
  5. In the Configuration tab, you can modify connector configuration details, or associated secret.
  6. Click Test Connection to verify if the configurations are correct to establish a successful connection to the data source.
  7. Click Apply Changes.
