Trino federation connectors
Learn about Trino federation connectors and how they enable access to remote data sources using Cloudera Lakehouse Engine.
Trino is a distributed SQL query engine designed from ground up around the concept of connectors and federation. Trino connectors help you connect to and access data from a variety of remote data sources, make each remote data source available within Trino as a catalog, and handle sending or receiving data from the remote source.
You can use Cloudera Lakehouse Engine to configure a connector for a data source, enabling a Trino Virtual Warehouse to access the data source. You can either create a Certified connector (tested and certified by Cloudera) or a Community connector.
When you create a certified connector, a template specific to the selected data source type is provided for you to specify the connector configuration details, such as connection URL and secrets that are required to access the data source. You can also choose community connectors that are powered by open-source Trino; however, these connectors are not directly supported by Cloudera and do not offer default configuration.
Cloudera enables you to configure connectors for the following data sources:
Certified Connectors
  • Amazon Redshift
  • Hive
  • Hive Engine
  • Hive-jdbc
  • Iceberg
  • Impala Engine
  • Impala-jdbc
  • Kudu
  • MariaDB
  • MySQL
  • Oracle
  • PostgreSQL
  • Snowflake
  • Teradata
Community Connectors
  • Apache Druid
  • Apache Hudi
  • Apache Ignite
  • Apache Kafka
  • Apache Pinot
  • Black Hole
  • Cassandra
  • ClickHouse
  • Delta Lake
  • DuckDB
  • Elasticsearch
  • Exasol
  • Google BigQuery
  • Google Sheets
  • Loki
  • Microsoft SQL Server
  • MongoDB
  • OpenSearch
  • Prometheus
  • Redis
  • SingleStore
  • TPC-DS
  • TPC-H
  • Vertica
