Role assignment for other users
To give other users or user groups access to a Cloudera Lakehouse Engine instance, assign the cle-admin or cle-viewer application role in the Anywhere Cloud Console.
  1. In the Anywhere Cloud Console, go to Admin Center > Security > Users and Groups.
  2. Click Assign Roles to Users.
  3. In the Select users from Identity Provider section, search for and select the users.
  4. In the Select roles section, select Application roles as the Role type.
  5. In the Engine section, select Cloudera Lakehouse Engine from the Engine type list, and then select the instance from the Engine Instance list.
  6. Turn on the toggle for one of the following roles:
    • cle-admin: Full administrative access to the Cloudera Lakehouse Engine Admin API.
    • cle-viewer: Read-only access to the Cloudera Lakehouse Engine Admin API.
