Role-based access control in Cloudera Lakehouse Engine
Cloudera Lakehouse Engine user roles, cle-admin and cle-viewer, control whether you can manage or only view connectors, secrets, and cluster configuration in a Cloudera Lakehouse Engine instance.
Cloudera Lakehouse Engine provides role-based access control for the Cloudera Lakehouse Engine UI, the Admin API, and the Admin Model Context Protocol (MCP) server. Administrators manage connectors, secrets, and cluster configurations, and hold full access across the Admin API and Admin MCP server. Viewers inspect permitted information without making changes and can call only read-only tools through the MCP server. Users without an applicable role cannot access the instance.
Roles and access levels
Cloudera Lakehouse Engine defines two roles that control the actions you can perform in the user interface and through the API and MCP.
Role Role value Access
Administrator <namespace>:cle-admin Full administrative read and write access in the matching namespace
Viewer <namespace>:cle-viewer Restricted, read-only access in the matching namespace.
In a role value, <namespace> is the namespace of the Cloudera Lakehouse Engine deployment. A role for a different namespace does not grant access.
Permissions by role
In the table, the administrator includes users with a matching <namespace>:cle-admin role and users with global:platform-admin. Viewer includes users and groups with a matching <namespace>:cle-viewer role.
Capability Administrator Viewer No applicable role
Access the Cloudera Lakehouse Engine Yes Yes, with a read-only warning No, an access-denied message appears in the UI and API returns HTTP 403 code.
List and inspect connectors Yes Yes, with credentials redacted No
Read stored connector credentials and credential-bearing values Yes No No
Read cluster configuration identity metadata Yes Yes No
Read cluster configuration bodies and effective values Yes No No
Create, edit, or delete connectors Yes No No
Modify cluster configuration, or add or delete configuration files Yes No No
Create, edit, or delete secrets Yes No No
Test connections Yes No, the control is hidden No
Apply or discard configuration changes Yes No, the controls are hidden No
Viewer data protections
Viewers with read-only access cannot see all configuration data. Cloudera Lakehouse Engine limits their visibility with these protections:
  • Connectors: Cloudera Lakehouse Engine redacts credentials, user names, credentials embedded in URLs, and sensitive values in auxiliary files. Non-credential values, and values that consist only of supported environment variables or secret file references, remain visible.
  • Cluster configuration: Viewers see identity metadata only, that is, name, directory, filename, scope, origin, and type. Cloudera Lakehouse Engine hides the configuration contents and effective values.
  • Write requests: Backend authorization checks reject write requests from viewers.
Default role for the deployer
When you deploy a Cloudera Lakehouse Engine instance, you automatically receive the cle-admin role for that instance. You can administer the instance without a separate role assignment.
Access without a role
If you open a Cloudera Lakehouse Engine instance without the cle-admin or cle-viewer role for that instance, the Access Restricted dialog box appears with the following message:
You do not have permission to access this Cloudera Lakehouse Engine instance. To request access, contact your administrator for one of the following roles:
  • cle-viewer (Read-only access)
  • cle-admin(Full administrative access)
Click Go Back To Anywhere Cloud to return to the Anywhere Cloud Console, and contact your administrator to request the role that you need.
