Blackhole connector
The Blackhole connector can be used as a sink where you can write any type of data into. The Blackhole connector works out of the box, no mandatory field is required to use the connector. The Blackhole connector is useful when you want to experiment and try out Cloudera SQL Stream Builder or to test your SQL queries using random data.
- Template: blackhole
- You do not need to provide any type of information when using the Blackhole connector and template.
