Connectors
Cloudera SQL Stream Builder supports different connector types and data formats for Flink SQL tables to ease development and access to all kinds of data sources.
The following table summarizes the supported connectors and how they can be used in Cloudera SQL Stream Builder:
Connector Type Description
Kafka source/sink Supported as exactly-once-sink
Hive source/sink Can be used as catalog
Kudu source/sink Can be used as catalog
Schema Registry source/sink Can be used as catalog
JDBC source/sink Can be used with Flink SQL. PostgreSQL, MySQL and Hive are supported.
Filesystems source/sink Filesystems such as HDFS, S3 and so on. Can be used with Flink SQL
Debezium CDC source Can be used with Flink SQL. PostgreSQL, MySQL, Oracle DB, Db2 and SQL Server are supported.
Webhook sink Can be used as HTTP POST/PUT with templates and headers
PostgreSQL sink Materialized View connection for reading views. Can be used with anything that reads PostgreSQL wire protocol
REST sink Materialized View connection for reading views. Can be used with anything that reads REST (such as notebooks, applications, and so on)
BlackHole sink Can be used with Flink SQL.
