The application you want to build determines the Cloudera Streaming Analytics deployment process
on Cloudera Private Cloud Base. You can choose between building either a DataStream application or a
SQL streaming application.
You can deploy Cloudera Streaming Analytics on Cloudera Private Cloud Base depending on the application you
want to build.
DataStream application using only Flink. In this case, you need to create a Flink
application cluster.
SQL Streaming application using Flink with Cloudera SQL Stream Builder. In this case, you need to
create a Streaming SQL cluster.
You can use the following workflow to have an understanding of the deployment process:
