Cloudera Base on premises cluster requirements
The Cloudera Base on premises cluster is used for Cloudera Data Catalog.
As Apache Atlas and Apache Ranger services are installed in the Base cluster, Cloudera Data Catalog communicates with these services to fetch metadata and security policies. Profilers connect with Hive and HDFS services running in the Base cluster for data profiling operations.
For more information, check the following links:
