Cloudera Data Catalog Profilers
Profilers create metadata annotations that summarize the content and shape characteristics of the data assets (such as distribution of values in a box plot or histogram).
Cloudera Data Catalog supports different environments:
  • When using the VM-based environment, you can create a Cloudera Data Hub cluster for a profiler engine to run data profiling operations as a pipeline on data located in one of your Data Lakes. You can install the profiler agent in a Data Lake and set up a specific schedule to generate various types of data profiles.
  • When using the Compute Cluster enabled environment, after launching a profiler cluster, an internal service provisions new Kubernetes pods, scheduling and running profiler jobs on-demand.
Profiler Name Description
Cluster Sensitivity Profiler The profiler automatically classifies your data with preconfigured tags, such as, PII, PCI, HIPAA and others.
Ranger Audit Profiler A Ranger audit log summarizer.
Hive Column Profiler Provides summary statistics like Maximum, Minimum, Mean, Unique, and Null values at the Hive column level.
Limitations
  • In VM-based environments (with Cloudera Data Hub workflows), profilers do not support Iceberg tables, however, they are discoverable. In Compute Cluster enabled environments, Iceberg tables can be profiled.
  • Supported file formats:
    • VM-based environments:
      • CSV
      • Avro
  • Compute Cluster based profilers might hang if the underlying AWS cloud provider environment cannot provide the necessary memory for the executor instances. In this case, reconfigure your executors with 4-5 GB memory in Profiler Details > Configuration.
