Flow Management clusters
Learn about the default Flow Management clusters, including cluster definition and template names, included services, and compatible Cloudera Runtime versions.
Flow Management delivers high-scale data ingestion, transformation, and management to enterprises from any-to-any environment. It addresses key enterprise use cases such as data movement, continuous data ingestion, log data ingestion, and acquisition of all types of streaming data including social, mobile, clickstream, and IoT data.
The Flow Management template includes a no-code data ingestion and management solution powered by Apache NiFi. With NiFi’s intuitive graphical interface and 300+ processors, Flow Management enables easy data ingestion and movement between Cloudera services as well as 3rd party cloud services. NiFi Registry is automatically set up and provides a central place to manage versioned Data Flows.
- Cluster definition names
Flow Management Light Duty for AWS
Flow Management Heavy Duty for AWS
- Cluster template name
- CDP - Flow Management: Light Duty
- CDP - Flow Management: Heavy Duty
- Included services
- NiFi
- NiFI Registry
- Compatible Cloudera Runtime versions
- 7.2.15
- 7.2.16
- 7.2.17
- 7.2.18
- 7.3.1
- 7.3.2
