Managing advanced settings
Cloudera Data Visualization allows users with administration privileges to configure several advanced settings.
Webhook
You can use webhooks to pass parameters to any API endpoint that you might want to update with a dashboard's parameters.
To interact with webhooks, check the Allow users to interact with webhooks option and enter the URLs in the URLs that webhook actions are permitted to interact with text box. If you add multiple values, separate them by a new line.
Remote data
To provide URLs for remote data, enter the URLs in the URLs that remote data columns can be fetched from text box. If you add multiple values, separate them by a new line.
Advanced site settings
You can configure various advanced settings in Cloudera Data Visualization by adding them to the Advanced Site Settings text box.
Availability of advanced site settings depends on deployment type. Advanced site settings are not available in Cloudera Data Warehouse deployments of Cloudera Data Visualization. For an overview of supported capabilities by deployment type, see Understanding Cloudera Data Visualization deployment options.
Autologin
Users with administrative privileges can enable unauthenticated access through automatic login:
In Cloudera AI, authentication for applications is enforced on all ports by default. If needed, an Admin user can allow users to create public applications accessible by unauthenticated users. This is needed if you do not want users to log into Cloudera AI. For information on how to enable unauthenticated access in Cloudera AI, see Public Applications in Securing Applications.
To configure autologin for a user in Cloudera Data Visualization, add the
following settings in the Advanced Site Settings text box in
key = value format:
AUTOLOGIN_ENABLED = True
AUTOLOGIN_USERNAME = "username"
AUTOLOGIN_PASSWORD = "password"
Concurrency
To configure concurrency, add the desired settings in the Advanced Site
Settings text box in key = value. The following
options are available:
DATACONNECTION_CONCURRENCY_DEFAULT |
Default number of concurrent requests per data connections |
DATACONNECTION_CONCURRENCY_MAX |
Maximum number of concurrent requests per data connections |
DATACONNECTION_CONCURRENCY_USER_DEFAULT |
Default number of concurrent requests per user |
DATACONNECTION_CONCURRENCY_USER_MAX |
Default number of maximum concurrent requests per user |
These settings control the number of concurrent requests per data connection and per user.
Data extracts
To configure data extracts, add the desired settings in the Advanced Site
Settings text box in key = value format. The
following options are available:
- Prefix for target table names
You can define a prefix for table names. The default value is cdv_.
DATA_EXTRACTS_TARGET_TABLENAME_PREFIX = "cdv_" - Maximum number of rows that can be inserted into a data connection by CDV using data extracts or CSV upload
You can set a system wide maximum value for the maximum number of rows for upload/import all connections.
UPLOAD_MAXROWS_MAX = 1000000000 - Number of rows inserted at a time through data import and data extract inserts
IMPORT_BATCH_INSERT = 1000
Notifications
To configure how long read notifications are kept in the Notifications
Center, add the
BULK_REMOVE_READ_NOTIFICATION_INTERVAL flag in the
Size limit for static asset upload
To configure the size limit for uploading static assets, add the
DATA_UPLOAD_MAX_MEMORY_SIZE flag in the Advanced
Filter association configuration
To enable Filter Association (FA) based on Manage dataset permission, add the
MANAGE_DS_FA = True flag in the Advanced Site
Settings text box.
