Exporting draft parameters to a parameter group
You can select a group of parameters and make them available for reuse in a workspace by exporting them as a parameter group.
When you want to share a group of parameters for reuse, use the Export Parameter Group option. This allows for the reuse of those parameters within the same project, without the need for copying and pasting them individually.
You need the DFFlowDeveloper role to manage flow drafts in the workload environment.
  1. On the Flow Design canvas, select Flow Options > Parameters.
  2. Select the All Parameters tab and click Export Parameter Group.
    The Export to a Shared Parameter Group modal opens.
  3. From the Project drop-down select an available project where you want to assign the new group, or leave it unassigned.
  4. Provide a Parameter Group Name. The name must be unique within a workspace, Cloudera Data Flow automatically validates the name.
  5. Optional: You can optionally provide a Description of the parameter group.
  6. Select Parameters to export by checking the boxes next to them. Select the checkbox on top to select all parameters.
  7. Optional: If you select the Import this Shared Group option the newly created shared parameter group will be automatically imported to the draft from which the parameters were originally exported, as the parameter group with the highest priority. Draft parameters with matching names will be replaced with parameters in the shared parameter group.
  8. Click Export.
