The values of properties in the flow, including sensitive properties, can be
parameterized. You can either create new parameters for your draft or import existing ones as a
parameter group.
The values of properties in the flow, including sensitive properties, can be parameterized
using Parameters. Parameters are created and configured within the Flow Designer. Any property
can be configured to reference a Parameter with the following conditions:
A sensitive property can only reference a sensitive parameter
A non-sensitive property can only reference a non-sensitive parameter
Parameters cannot be referenced in reporting tasks or in management controller services
Draft parameters
Any parameter defined in the root process group of the flow draft is a draft parameter. These
parameters can be directly modified in Flow Designer, their values always take precedence over
any parameter in a shared parameter group.
When you start a test session, a set of draft parameters required for provisioning the
underlying NiFi cluster, such as CDPEnvironment, and Default SSL Context Keystore are
auto-generated.
Parameter groups
You can create groups of parameters that can be shared within a project. This allows you to
fill in parameter values for several flow definitions, without having to copy and paste those
values every time they change. Furthermore, changing the value of a parameter in a parameter
group is propagated to any running test session which has components referencing the changed
parameter. For example, you create a group of sensitive parameters for credentials, and you
change the password. This change is disseminated in real time, and instead of failing, all test
sessions keep on running without manual intervention.
Assets (file type parameters) are also available in parameter groups, and they have a very
important advantage: you do not need a running test session to upload the asset, which is
otherwise a limitation of draft parameters.
To prevent crashes by accidental or malicious deletion, users cannot delete parameters in a
parameter group that has a running component referencing it.
When creating a flow draft in Flow Designer, you encounter
parameter groups in the following contexts:
While opening a flow definition from the Catalog
If the source flow definition contains more than one parameter context attached to the root
process group, the Flow Designer matches those contexts to shared parameter groups that are
assigned to the same project where the draft is created (In this respect ‘unassigned’ is
treated as a project of its own: an unassigned draft is matched to unassigned parameter
groups). Matching happens by name, and you are provided with a table of the results on the
Convert Parameters page. In this view you can examine and modify the
results of parameter matching. You can manually replace parameter contexts of the source flow
definition with other shared parameter groups available in the project that you find more
suitable to your needs. You can also create parameter groups from draft parameters.
While building a flow draft
In the Parameters view of the Flow Designer you can import
existing shared parameter groups and you can also export a number of draft parameters to a
parameter group which can then be reused in multiple flows.
Relationship between shared parameters and draft parameters
Precedence
The values of draft parameters always take precedence over imported parameters.
In case of imported parameter groups, their order defines precedence. By changing the
order of parameter groups, you can redefine precedence. As a result of this, if a parameter
is present in several shared parameter groups, the value of the one in the topmost group
takes precedence.
Value retention
Both non-sensitive and sensitive parameters that are part of an imported parameter group
keep the values they have in the shared parameter group. These values cannot be changed
within the Flow Designer, only in the Resources view.
Non-sensitive parameters that are added as draft parameters to the root parameter
context during draft creation retain the default values they had in the source flow
definition.
Sensitive parameters that are added as draft parameters to the root parameter context
during draft creation are added without values.
'Update Parameters' alert
These alerts occur when a parameter group, referenced in one or more parameter contexts, has
been modified. The actual change to the parameter group may or may not affect your flow draft,
as Cloudera Data Flow has no information on the nature of the change, it simply
registers the fact that a newer version of the parameter group became available.
A parameter group you referenced in one or more parameter contexts earlier, was modified.
You are only required to Update Parameters if you want to reference a
new parameter from the updated parameter group, in a parameter context already referencing
parameters from that group. This is because Cloudera Data Flow does not
reference multiple versions of the same parameter group in the same parameter context. Unless
you opt for the Update All Parameter Contexts option, any other parameter
context referencing an earlier version of the same parameter group stays on that earlier
version.
You do not need to Update Parameters and you are still able to apply
any future changes in the following cases:
You want to reference the updated parameter group in a parameter context not already
referencing it.
You want to reference a different parameter group in the parameter context referencing the
updated parameter group.
You want to provide a custom value to any parameter in any of the parameter contexts.
