Queue management
You can remove all flow files from a selected connection or all flow files on process group level.
- Make sure that you have DFDeveloper permission to perform this task. For information on account and resource roles, see Cloudera Data Flow Authorization.
- You have an active test session.
To view the queue of a connection, right click on the connection and select
List Queue.
The top 100 flow files are listed on the List Queue
page.
Emptying a queue
Learn how to delete enqueued flow files from a connection.
Emptying all queues
Learn how to delete enqueued flow files from all connections on Process Group level.
