Creating a draft from a flow definition in the Catalog
You can open flow definitions in the Catalog as drafts in Flow Designer. Depending on whether the flow definition has associated flow drafts or not, you may have more than one option.
  • You have an enabled and healthy Cloudera Data Flow environment.
  • You have been assigned the DFDeveloper role granting you access to the Flow Designer.
  • You have been assigned the DFCatalogAdmin or DFCatalogViewer role granting you access to the entire Catalog, or DFCollectionMember role granting you access to the specific collection where the flow definition is located. You will need this authorization to view and open flow definitions, and to publish your draft as a flow definition to the Catalog or a specific Catalog collection.
If you have sufficient rights, you can create a new draft from existing flow definitions in the Catalog. This gives you two options:
  • You can update the existing flow definition by creating a draft and then publishing your work as a new version of the source flow definition.
  • You can create a draft using the source flow definition as a template and then publish your work as a new flow definition.
  1. Open Cloudera Data Flow by clicking the Data Flow tile in the Cloudera sidebar.
  2. Select Catalog in the left navigation pane.
  3. Select the flow that you want to open as a draft.
  4. Depending on whether there already is one or more associated draft for the selected flow, you may have two options to select from:
    • If there is one or more ASSOCIATED DRAFT, you can select that and the draft opens for editing in the Flow Design view.
    • If there are no associated drafts or you want to create a new flow based on the selected one, click Actions > Create New Draft (In case of ReadyFlows, you see the Create New Draft option, as there are no other available actions.)
  5. Click Create.
    If the source flow definition contains more than one parameter context, the Map Parameter Contexts page opens. If parameter matching is not necessary, the draft opens in the Flow Designer.
  6. If the source flow definition contains more than one parameter context, the Map Parameter Contexts page opens. This is the step where you can review the suggested shared parameter groups to replace parameter contexts in your flow definitions.
    For more information on parameter matching, see Parameter matching .
  7. Click Create Flow Draft.
Proceed according to Creating a draft.
