Publishing a draft as a new version of an existing flow definition
If you opened an existing flow definition from the Catalog as a draft, you have the option to publish your updates as a new version of the source flow definition.
- Make sure that you have DFDeveloper permission to perform this task. For information on account and resource roles, see Cloudera Data Flow Authorization.
- Make sure you have DFCatalogPublisher permission to perform this task. For information on account and resource roles, see Cloudera Data Flow Authorization.
- You have created a draft from an existing flow definition in Flow Designer.
