Stopping a test session
You can stop a test session to reconfigure your NiFi cluster. You can continue editing your draft flow in the meantime.
  • Make sure that you have DFDeveloper permission to perform this task. For information on account and resource roles, see Cloudera Data Flow Authorization.
  • You have an active test session.
  1. You have two options to end an active test session:
    • Click the toggle next to the Active Test Session notification.
    • Click Flow Options then click Stop under Test Session.
  2. Click End.
    Test session status first changes to Ending Test Session... then, after the NiFi cluster shuts down, it changes to Test Session Not Active.
Once the test session stops, you can update the configuration of your NiFi testbed cluster. To do so, select Flow Options > Test Session > Edit Configuration.
