Adding inbound connection support to a draft
You can enable a dataflow to listen on a public endpoint to data sources that are
outside your Cloudera on cloud environment by adding inbound
connection support to your draft.
To enable your dataflow to use listen processors with inbound connection endpoint support, make the following addition to your draft:
- Open the draft where you want to enable inbound connection support.
- Add the required listen processor to your draft.
Cloudera Data Flow supports all listen processors, including custom processors.
Configure the processor to enable inbound connections.
- Port
- Provide a port number where the flow deployment listens for incoming data. You can either add it as a parameter by clicking to make the actual port number configurable during flow deployment, or you can set an explicit port number when creating the draft.
- SSL Context Service
- Create an external StandardRestrictedSSLContextService for your processor, by clicking and filtering for StandardRestrictedSSLContextService. You must name this context service Inbound SSL Context Service. No other configuration is required. The SSL context service will be created during cluster deployment and all other properties will be populated with values generated for that NiFi cluster.
- Client Auth
- Set to “REQUIRED” to use mTLS.
