Adding a service to your draft
Learn how you can add a service in Cloudera Data Flow Flow Designer.
- Make sure that you have DFDeveloper permission to perform this task. For information on account and resource roles, see Cloudera Data Flow authorization.
- You have created a draft flow in Cloudera Data Flow Flow Designer.
Adding a service from Flow Options
Learn about creating services from the Flow Options menu.
Creating a service from Configuration
Learn how you can create services directly from the Configuration pane for a property that expects a controller service as a value.
