Creating DraftsPDF version
Copying and pasting processors
In Flow Designer you can copy processors together with their configuration and then paste them to the same or another draft, or to an external application.
Copying a processor copies the entire processor configuration to the clipboard, even sensitive properties are kept. If you paste the processor to a different draft, you may still get an error as, for example, services are not copied together with your processor and you will have to recreate those in the new draft.
  1. Select the processor you want to copy then either right-click on it and select Copy to clipboard or press ⌘+C.
  2. To paste the processor, press ⌘+V.
