Managing flow definitions using the Catalog
In Cloudera Data Flow, your flow definitions are available in the Catalog. You can browse, discover, and manage flow definition versions in this view. You can also deploy and reuse your flow definitions across multiple environments.
- Make sure that you have sufficient permissions for the task you want to perform. For information on account and resource roles, see Cloudera Data Flow Authorization.
- Import your Apache NiFi flow into Cloudera Data Flow, or publish your draft from Flow Designer to make it available as a flow definition in the Catalog.
- Organize your flow definitions into collections to implement fine grained, role-based access control.
