Catalog view
Learn the information that you can track in the Catalog page. Also, learn how to sort, search, and refresh your flow definitions.
You can track the following details of flow definitions in the Catalog
page:
- Name – Name of the flow definition
- Collection – Affiliation of the flow definition - flow definitions can either be unassigned, accessible to any user with appropriate permissions to the catalog or assigned to a collection, where they are only accessible to users with permission to that specific collection.
- Versions – Number of available versions
- Last Updated – When the flow definition was last changed
You can sort flow definitions by Name, Type and Last Updated. Click the column name to sort by ascending or descending order.
You can also use the Search field at the top of the Flow Catalog page to directly search for the flow definition by its name.
You can use the Items per page option, at the bottom of the screen, to display the desired number of flow definitions in your page view.
You can click the Refresh button in the top right corner
to refresh the data. By default, every 30 seconds all data for your flow definitions are
updated.
