Learn how to
create the Hello World ReadyFlow as a starting point for your custom flow in the Flow
Designer.
ReadyFlows are read-only, therefore you cannot publish a
new version of them. When you are done with creating your customized version of the
given ReadyFlow, you can
only
publish your work to the Catalog as a new flow
definition.
You
must
have an enabled and healthy Cloudera Data Flow environment.
You
must
be
assigned the
DFDeveloper
role granting you access to the Flow Designer.
You
must
be
assigned the
DFCatalogAdmin
or
DFCatalogViewer
Catalog.
You will need this authorization to publish your draft flow as a flow
definition to the
Catalog.
You
must
be
assigned the
DFFlowAdmin
role for the environment to which you want to deploy the flow
definition.
Open Cloudera Data Flow by clicking the
DataFlow tile in the Cloudera sidebar.
Select the
ReadyFlow
Gallery
item
in the left navigation pane.
Select the Hello World ReadyFlow.
Click the
Create New
Draft
button.
Select the target Workspace where you want to create the
draft flow.
Provide a
valid name
in the
Draft
Name
field
for the draft flow.
Flow names must be unique within a workspace. If a draft with the provided
name already exists, you
must
provide a different name.
Click the
Create
button.
Hello World opens as a draft in the designated
Flow
Designer workspace with the
Draft
Name you provided on the Flow Design
canvas.
Proceed with creating the necessary Controller
Services.
