Cloudera Documentation
Configuring Spark application properties in spark-defaults.conf
Specify properties in the spark-defaults.conf file in the form property=value.
To create a comment, add a hash mark ( # ) at the beginning of a line. You cannot add comments to the end or middle of a line.
This example shows an example excerpt of a spark-defaults.conf file:
spark.authenticate=false
spark.driver.log.dfsDir=/user/spark/driverLogs
spark.driver.log.persistToDfs.enabled=true
spark.dynamicAllocation.enabled=true
spark.dynamicAllocation.executorIdleTimeout=60
spark.dynamicAllocation.minExecutors=0
spark.dynamicAllocation.schedulerBacklogTimeout=1
spark.eventLog.enabled=true
spark.io.encryption.enabled=false
spark.lineage.enabled=true
spark.network.crypto.enabled=false
spark.serializer=org.apache.spark.serializer.KryoSerializer
spark.shuffle.service.enabled=true
spark.shuffle.service.port=7337
spark.ui.enabled=true
spark.ui.killEnabled=true
spark.yarn.access.hadoopFileSystems=s3a://bucket1,s3a://bucket2
Cloudera recommends placing configuration properties that you want to use for every application in spark-defaults.conf. See Application Properties for more information.
