1.4. Troubleshooting Ambari
Use these topics to help troubleshoot any issues you might have installing Ambari with an existing Oracle database.
 1.4.1. Problem: Ambari Server Fails to Start: No Driver
Check /var/log/ambari-server/ambari-server.log for the following error:
ExceptionDescription:Configurationerror.Class[oracle.jdbc.driver.OracleDriver] not found.
 1.4.1.1. Solution
Make sure the file is in the appropriate directory on the Ambari server and re-run ambari-server setup. Review the load database procedure appropriate for your database type in Using Non-Default Databases - Ambari.
 1.4.2. Problem: Ambari Server Fails to Start: No Connection
The Network Adapter could not establish the connection Error Code: 17002
Ambari Server cannot connect to the database.
 1.4.2.1. Solution
Confirm that the database host is reachable from the Ambari Server and is correctly configured by reading /etc/ambari-server/conf/ambari.properties. server.jdbc.url=jdbc:oracle:thin:@oracle.database.hostname:1521/ambaridb server.jdbc.rca.url=jdbc:oracle:thin:@oracle.database.hostname:1521/ambari
 1.4.3. Problem: Ambari Server Fails to Start: Bad Username
Internal Exception: java.sql.SQLException:ORA­01017: invalid username/password; logon denied
You are using an invalid username/password.
 1.4.3.1. Solution
Confirm the user account is set up in the database and has the correct privileges. See Step 3 above.
 1.4.4. Problem: Ambari Server Fails to Start: No Schema
Internal Exception: java.sql.SQLSyntaxErrorException: ORA­00942: table or view does not exist
The schema has not been loaded.
 1.4.4.1. Solution
Confirm you have loaded the database schema. Review the load database schema procedure appropriate for your database type in Using Non-Default Databases - Ambari.
