On the Ambari Server host, stage the appropriate PostgreSQL connector for later deployment.
Install the connector.
RHEL/CentOS/Oracle Linux
yum install postgresql-jdbc
SLES
UBUNTU
apt-get install -y postgresql-jdbc
Copy the connector.jar file to the Java share directory.
cp /usr/share/pgsql/postgresql-*.jdbc3.jar /usr/share/java/postgresql-jdbc.jar
Confirm that .jar is in the Java share directory.
Change the access mode of the .jar file to 644.
ambari-server setup --jdbc-db=postgres --jdbc-driver=/usr/share/java/postgresql-connector-java.jar
Create a user for Oozie and grant it permissions.
Where <OOZIEUSER> is the Oozie user name, <OOZIEPASSWORD> is the Oozie user password and <OOZIEDATABASE> is the Oozie database name.
