On the Ambari Server host, install the connector.
Install the connector
RHEL/CentOS/Oracle Linux
SLES
Confirm that
.jar
is in the Java share directory.ls /usr/share/java/mysql-connector-java.jar
Make sure the .jar file has the appropriate permissions - 644.
Create a user for Ambari and grant it permissions.
For example, using the MySQL database admin utility:
# mysql -u root -p
FLUSH PRIVILEGES;
Where
<AMBARIUSER>
is the Ambari user name,<AMBARIPASSWORD>
is the Ambari user password and<AMBARISERVERFQDN>
is the Fully Qualified Domain Name of the Ambari Server host.
You must pre-load the Ambari database schema into your MySQL database using the schema script.
mysql -u <AMBARIUSER> -p
CREATE DATABASE
<AMBARIDATABASE>
USE <AMBARIDATABASE>;
SOURCE Ambari-DDL-MySQL-CREATE.sql;
Where <AMBARIUSER> is the Ambari user name and <AMBARIDATABASE> is the Ambari database name.
Find the
file in the/var/lib/ambari-server/resources/
Advanced Database Configuration > Option [3] MySQL
and enter the credentials you defined in Step 2. for user name, password and database name.
