1.2. Using Ambari with MySQL/MariaDB
  1. On the Ambari Server host, install the connector.
    1. Install the connector
      RHEL/CentOS/Oracle Linux
      SLES
      Ubuntu
      apt-get install mysql-connector-java
      Debian
  2. Create a user for Ambari and grant it permissions.
    • For example, using the MySQL database admin utility:
      # mysql -u root -p
      FLUSH PRIVILEGES;
    • Where <AMBARIUSER> is the Ambari user name, <AMBARIPASSWORD> is the Ambari user password and <AMBARISERVERFQDN> is the Fully Qualified Domain Name of the Ambari Server host.
    • You must pre-load the Ambari database schema into your MySQL/MariaDB database using the schema script.
      mysql -u <AMBARIUSER> -p
      USE <AMBARIDATABASE>;
      SOURCE Ambari-DDL-MySQL-CREATE.sql;
    • Where <AMBARIUSER> is the Ambari user name and <AMBARIDATABASE> is the Ambari database name.
      Find the Ambari-DDL-MySQL-CREATE.sql file in the /var/lib/ambari-server/resources/ directory of the Ambari Server host after you have installed Ambari Server.
  4. When setting up the Ambari Server, select Advanced Database Configuration > Option [3] MySQL/MariaDB and enter the credentials you defined in Step 2. for user name, password and database name.
