Upgrade Mahout. On the Mahout client host machine, execute the following command:
For RHEL/CentOS:
yum upgrade mahout-0.7.0.1.3.0.0
For SLES:
zypper remove mahout zypper se -s mahout
You should see Mahout v0.7.0.1.3.0.0 in the output. Install Mahout v0.7.0.1.3.0.0:
zypper install mahout-0.7.0.1.3.0.0
Important When removing and installing packages, rename those files the
/conf
directory that have.rpmsave
extension to original to retain the customized configs. Alternatively, you can also use the configuration files (under the/conf
directory) you backed up before upgrading.
